Postby G3750 » Wed Dec 21, 2022 11:40 am
healey36 wrote:Okay. Reading along over on that "other" forum, I wasn't sure if you were still pursuing that objective.
Yes, I absolutely am. I would like to take that module to a show or meeting at some point in 2023. And that will require the assistance of someone with an SUV - it definitely won't fit in the car.
Sometimes it's hard to keep up with all the forums. :oops:
Postby G3750 » Sun Jan 08, 2023 9:33 pm
Updated 1/8/2023:
In honor of MTJ not being dead :lol: and my train room actually being clean :shock: , here are some photos.
https://www.icloud.com/sharedalbum/#B0mJsHvHoAvyVe
Jim K
Postby Jim K » Mon Jan 09, 2023 8:26 pm
That is one nice bridge or maybe BRIDGE!
Postby G3750 » Mon Jan 09, 2023 9:44 pm
Postby webenda » Thu Jan 12, 2023 12:36 pm
G3750 wrote:Updated 1/8/2023:
Thank you for the pictures, George. I see the smoke stacks waiting to be put in place.
I learned from reading your posts that the steel mill is going to have smoke and lights.
Maybe it will look like this?
Postby G3750 » Thu Jan 12, 2023 11:57 pm
Wayne,
That's the plan! I want it to look as realistic as I can make it - sounds, lights, smoke! Everything but the air pollution. If you look very carefully at the photo of the train room in my original post on this subject, you will see that I have installed a fan in the divider (the photos of the blast furnaces). There's a duct behind it that will divert smoke from the Open Hearth stacks out the basement window.
Yeah, I'm that crazy. :shock: :lol:
Postby G3750 » Fri Jan 20, 2023 1:42 pm
Updated 1/20/2023:
Over on OGR, a thread about Lionel (ex MTH) Decapods announced in the new catalog triggered a comparison between them and the 3rd Rail engines. That morphed into comments about minimum curve requirements of each. This past Sunday I held an open house (layout tour) for the Panhandle. With a number of people in the room, I thought about aisle space when the layout was completed. All of the above sparked an analysis of the track plan.
Here's what I've learned:
  • 3rd Rail Decapods, both long tender and short tender versions, will run on O64 track. The short tender version will even run on O54.
  • Changing the curves on the Weirton peninsula from O72 to O64 will buy me another 12" of aisle space at the front of the layout (where space is at a premium). The Weirton peninsula is not yet built (not even benchwork exists). The aisle paralleling the bridge is unaffected.
  • Twelve (12) GarGraves O63 sections make up a full circle. Ross uses 16 O64 sections to make a circle, which gives me much more flexibility in accommodating yards and switches.
  • Because the Weirton Junction Yard planned to use O64 Ross switches, minimal disruption will occur in that area (again, still unbuilt).
  • A modification at this point will require replacement of one already installed O72 switch. This is not a big deal.
  • 18" passenger cars should be minimally affected by the change.
  • No other locomotives in my fleet are affected by the change.
  • The full effect on yards and the buildings of North Weirton is still TBD.
I am re-working my track plan on RR-Track and still exploring potential impacts, but at this early stage things look promising. Going to O64 is a small compromise that might lead to an improved accommodation of people in the train room.
More when I have finished the analysis.
Postby healey36 » Fri Jan 20, 2023 2:16 pm
Reading this has me realizing how far you have yet to go. Press on, undaunted!
Postby G3750 » Fri Jan 20, 2023 4:44 pm
healey36 wrote:Reading this has me realizing how far you have yet to go. Press on, undaunted!
Thank you! I am not daunted. Progress has been steady, but slow (by my standards). We are taking steps to accelerate the building process once I get this Open Hearth monkey off my back. :lol:
Postby healey36 » Fri Jan 20, 2023 6:00 pm
A couple of Red Bulls and a steady stream of black coffee and you can work straight through the night...
Postby G3750 » Sat Jan 21, 2023 11:03 am
healey36 wrote:A couple of Red Bulls and a steady stream of black coffee and you can work straight through the night...
Yeah, no problem. :lol: :lol: :lol: :lol: :lol:
Should be done - fully sceniced - in a week. :shock:
I'll get right on it. :wink:
Postby G3750 » Sun Jan 22, 2023 8:52 pm
Updated 1/22/2023:
After further review, the call on the ice still stands. I will be making changes to the layout. Here they are:
Switches 11, 12, 34, 43, 44 are eliminated
Switches 10, 35, 36 are replaced with RH O64s
Switch 9 - replaced with standard RH 11 degree
Switch 14 - replaced with LH O64
Weirton Junction Yard loses 2 freight car tracks but becomes slightly longer.
The aisle at the front (running along the bottom of drawing) picks up 1 extra foot in width along most of its length. This is the most significant gain and to my mind trumps all other advantages and disadvantages.
Postby healey36 » Mon Jan 23, 2023 9:33 am
Aisle space equates to ease of movement around the layout. Even three or four feet can get pretty congested if you have a bunch of visitors milling around. I would think anything you can do to expand tight aisle space without seriously degrading/compressing the track plan is time well-spent.
My two cents...
Postby Rufus T. Firefly » Mon Jan 23, 2023 12:40 pm
healey36 wrote:Even three or four feet can get pretty congested if you have a bunch of visitors milling around.
Liberal application of a cattle prod addresses that rather well.
Postby G3750 » Mon Jan 23, 2023 9:46 pm
healey36 wrote:Aisle space equates to ease of movement around the layout. Even three or four feet can get pretty congested if you have a bunch of visitors milling around. I would think anything you can do to expand tight aisle space without seriously degrading/compressing the track plan is time well-spent.
My two cents...
Thanks Healey!
And Rufus, do you prefer an electric or gas-powered cattle prod? Which do you find most advantageous?
Asking for a friend... :lol:
Users browsing this forum: Bing [Bot] and 25 guests
