Doorstop four axle Diesels
Re: Doorstop four axle Diesels
Postby bob turner » Mon Apr 22, 2024 1:23 pm
Here is my only Shark:
Postby R.K. Maroon » Tue Apr 23, 2024 11:55 pm
bob turner wrote:I think it is Lou
You are of course correct -- I clearly merged Jack Collier with Lou Houlemarde and got Jack Houlemarde. I have edited the post to fix this error.
bob turner wrote:Nice early FT models - why not guess at early Exacta? Seems to me they incrementally improved the FT models, although I have seen some truly awful examples that maybe preceded these
Anything is possible, as the documentation on many of these models is thin. Having said that, Exacta ran almost 30 advertisements in Model Railroading and issued a catalog as well. There is ample documentation of the Exacta cast E7 AB set but no mention of a freight diesel. Also, I might be more inclined if the Exacta E7 and this FT set were more similar in construction. As it is, the E7 is all cast while the FTs have sheet brass sides. The E7s have rivets, the FTs do not. The chassis and drives are not at all similar either. The E7 drive closely resembles the CLW drive in their cast PA, and similarly does not have a separate chassis. The FTs have machined chassis and drive that are very different:
https://www.dropbox.com/s/kilvpl03w3769b8/Jack%20Collier%20EMD%20FT%20Chassis%2001.JPG
It doesn't prove anything, but I wouldn't bet on Exacta.
bob turner wrote:Here is my only Shark
I too have lone PRR RF-16A Shark. It arrived long before the ABA set showed up:
https://www.dropbox.com/s/68nlan2hchl8rhj/Penn-Erie%20Shark%20PRR%202004_02.JPG
It needs a little touch-up, but it has CLW sprung trucks and a CLW drive. I haven't tried to run it with ABA set, and wouldn't have any idea if an ABAA lash-up would be realistic or not.
steamaheadstephen59
Postby steamaheadstephen59 » Wed Apr 24, 2024 11:29 pm
I have two RF-16 sharks or shells, how did you join the to halves. I was thinking of soldering them together using that aluminium solder you find advertised on some web sites. The stuff actually works, but needs a lot of heat and doesn't flow or run into a joint, its more like brazing, but how did you do it?
Postby R.K. Maroon » Wed Apr 24, 2024 11:53 pm
I have more Penn-Erie models than I am willing to admit too. I did not assemble any of them. I am going from memory, but I recall that one or two of them were actually TIG-welded together. Not many modelers have the setup or skill for that. The vast majority of the models were epoxied together. I will double check this on the four factory models I have and report back. I am leery of epoxy, but if these factory models are holding together with no obvious degradation after fifty-plus years, then I would find it harder to argue that epoxy is not a viable option. Others may have different opinions. I have tried the aluminum brazing rod (but not on cast aluminum). I found it very hard to get a decent bead.
If I were to ever build up a casting set, I would fabricated backing splints across the joints. One at the nose, one or two in the roof, and one in the rear bulkhead. The factory Penn-Erie U5Bs, which were sold assembled at one point by Penn-Erie, are notable for the presence of a long screw through nose, used to hold the shells together. There may be a screw at the rear of the shell as well. I have not seen any other units with this screw, including the U33C and U50 factory models.
steamaheadstephen59
Postby steamaheadstephen59 » Thu Apr 25, 2024 3:57 am
Thanks Jim, you're right the aluminium solder is not easy to use, but seams strong enough when you get it to work.
Postby R.K. Maroon » Sun Apr 28, 2024 9:42 pm
(Edited to update photo links)
Here are a few photos as a follow-up on assembling the Penn-Erie shells. First, a U25B, which arrived painted and decaled for NYC but without a chassis:
https://dl.dropbox.com/scl/fi/oktrby7kpz3kvy3qw56d0/Penn-Erie-GE-U25B-NYC-2500.jpg?rlkey=c4v28v3p7vxepjxbxav6ei0f1
The shell is bonded together, almost certainly with epoxy. As mentioned before, it is known that Penn-Erie sold the U25B shells already assembled with screws at each end to hold the shell together. The screws are a little hard to see in the photo here, but can been seen more clearly by clicking the link under the photo (which takes you to a larger image.
Here is another U25B, known to be a factory-built display model. It is also bonded together and has the reinforcing screws at each end:
https://dl.dropbox.com/scl/fi/3nq4ylkz9qkm1qz2rc3fz/Penn-Erie-GE-U25B-NH-2503.jpg?rlkey=g34me5ctj79b51be48xtogdq7
Finally, here is a later model, a U33B:
https://dl.dropbox.com/scl/fi/0nqfcm9dvy7lwi3anaxuf/Penn-Erie-GE-U33B.jpg?rlkey=g15tckmx5ukk147718n8ge76f
The shell is bonded together but there are no screws. It seems pretty clear that bonding the shells together is perfectly viable. Screws don't seem to be needed either, as most of my Penn-Erie models do not have them. But it can't hurt either.
One last thing: I mentioned that I would use backup pieces across the joint. Bob T. reports that a patch of epoxy-infused fiberglas cloth across the joint is quick and easy. While you don't get the mechanical strength that a metal plate gives you, Bob's patch seems like a good compromise -- stronger than just a seam bond but much easier to install.
steamaheadstephen59
Postby steamaheadstephen59 » Tue Apr 30, 2024 8:09 pm
Thanks for the pictures and information, the fiberglass matting sounds like a good idea.
Postby bob turner » Tue Apr 30, 2024 8:40 pm
These models do not see severe service.
I broke a toilet tank three decades ago - JB Weld and Fiberglas cloth, and it lasted a quarter century - it did not fail; the Greek just wanted one of those new toilets that only flush successfully when they feel like it.
I did a Hudson tender in 1966 by using two of those shorter Lionel die cast tenders carefully spliced together. I used epoxy, but was unaware of JB Weld. This stuff was dime store epoxy. Glass cloth is the same. Still together behind my 2-railed 763.
Do not hesitate to use epoxy on aluminum or die cast. No need to weld or solder.
Postby ScaleCraft » Tue Apr 30, 2024 9:56 pm
And now JB Quick sets faster.
Had an emissions device let go on our Explorer on vacation, torched a slot in the side of the plastic intake plenum.
Stopped at NAPA, bought some JB Quick and black tape, fixed it, and it's been almost 20 year now.
Years ago, a friend ran an automotive machine shop.
An old farmer brought in a flathead six Dodge, with a wrist pin that came adrift in the piston, and made one helluva groove in the cylinder wall.
He did not have the money for sleeving the cylinder, new pistons or rings.
My buddy stripped it, hot tanked it, JB Weld the groove, next day power honed that cylinder, re-assembled with new gaskets, and last I heard, it was still running.
steamaheadstephen59
Postby steamaheadstephen59 » Thu May 02, 2024 11:55 pm
I checked out a few videos on You Tub, JB weld certainly has a reputation as an epoxy glue. In Australia I found a couple of suppliers, I will be getting some!!
Postby R.K. Maroon » Sat May 04, 2024 1:39 am
Here is another set of doorstop four-axle diesels -- an ABA set of FTs -- purchased on eBay in October 2011:
https://dl.dropbox.com/scl/fi/wwqzb0agpn3v0jrgnbbew/WCCo-Adams_GN_FT_01.JPG?rlkey=s74tvk1zajkc2dzggc5ganzro
https://dl.dropbox.com/scl/fi/2yylx899olkts10r7retv/WCCo-Adams_GN_FT_03.JPG?rlkey=ir8s1q1yfcoe3y1g2peslchkp
https://dl.dropbox.com/scl/fi/1x0iznbldmlctrsg8a1wj/WCCo-Adams_GN_FT_02.JPG?rlkey=our83l3u4pnpbsrjum6okvrjq
Hmm...I am getting the "broken link" icon for the images, but when I click on the "backup" link, the image appears. I will be interested to know if anybody out there is seeing the images just fine or if everybody is getting the same broken link icon.
UPDATE: Discovered a fix (or more accurately, a hack) to work around the issue. Images should show now for most people. The secondary link under the image should still work too
It's always something, and if it's not something, it's something else
sleepmac
Postby sleepmac » Sat May 04, 2024 8:32 am
The photos don't show up on MTJ, but they show up when I select the links. Thanks for posting the photos.
Postby R.K. Maroon » Sat May 04, 2024 11:14 pm
I found a work-around for the problem I was having with images not being displayed. It's not a great solution, however, as I would have to go back and edit every old post that has a broken link and manually edit the text of the link.
Are we having fun yet?
steamaheadstephen59
Postby steamaheadstephen59 » Sun May 05, 2024 8:53 pm
Well I can see the images just fine, without the link so thats good. So are these Exacta models? or Adams and Sons
Postby R.K. Maroon » Tue May 07, 2024 12:05 am
steamaheadstephen59 wrote:So are these Exacta models? or Adams and Sons
The units are widely known as Adams and Son (just one son). This is mostly true but there are some caveats. Adams and Son was a the foundry, first in Corsicana, Texas and later in Wichita, Kansas. They sold a casting set for the FT for several years starting in 1947. Henry Pearce eventually wound up with the patterns and continued to sell the casting sets at least into the early 1960s. Documentation indicates that the Adams and Son castings were bronze and the Pearce castings were brass, but no distinction is made when these are talked about or sold -- everybody calls them Adams and Son. My issue with calling all of these Adams and Son is that A&S never offered a drive or a full kit for this model. Calling them Adams and Son ignores the wildly non-trivial effort to assemble the castings, fabricate and install a drive, and finish the model.
While many of these models have been built up by individual modelers, at least two companies offered complete versions. The best documented is Diesel Model Company of Dallas, which ran ads for these in the late 1940s, They were sold with the shell soldered together and the chassis assembled. The other known source for these is a company known only as WCCo. No documentation on this company has been found, but the Great Northern units pictured above are marked WCCo and are serialized: 146A, 146B, and 147A. Amazingly, 147B was found in Southern colors many years later:
https://dl.dropbox.com/scl/fi/r6nh08ctg3cva7jm1q3x4/A-S-WCCo-FT-SRR-B-2_01.jpg?rlkey=ps14ktnvnv9f4yurjnpbxh60m
A total of six WCCo units have been found -- three AB sets with matching serial numbers. The third set is serial number 87, leading one to believe there must be more out there.
One last thing: a little-known company called Baker Bros. sold a power truck for this casting set (and any other F-unit that came along). The Great Northern units came with these installed:
https://www.dropbox.com/s/dwj3mhdhz2sh0tf/WCCo-Adams%20Drive%2004.JPG
I have examples of these with chain drive (as shown), spur gears, and spring belts. Unlike a lot of other early diesel drives, these often show up in operable condition.
