PRR Locomotives
big bad jim
Re: PRR Locomotives
Postby big bad jim » Sat Oct 24, 2020 9:12 pm
Still no luck on my end. I also can think of nothing that has changed that would cause the issue. My hope is that if something randomly changed that caused the problem, then some other random event may change it back eventually. Fingers crossed, they were some great photos.
Re: PRR Locomotives
Postby rogruth » Sat Oct 24, 2020 10:16 pm
I'm sure you have but have you shut down and restarted your computer?
PRRK4s
Re: PRR Locomotives
Postby PRRK4s » Sun Oct 25, 2020 7:43 am
big bad jim
Re: PRR Locomotives
Postby big bad jim » Sun Oct 25, 2020 4:23 pm
rogruth wrote:I'm sure you have but have you shut down and restarted your computer?
Yeah, all the usual resets have been tried, to no avail at the moment. I'm sure it's some quirky thing that would defy reason, if I even ever figure out what's going on. In the mean time, the world keeps turning. 8)
Re: PRR Locomotives
Postby rogruth » Sun Oct 25, 2020 5:50 pm
Like my transformer problem, no one has aver had it before.
Re: PRR Locomotives
Postby Rufus T. Firefly » Sun Oct 25, 2020 6:01 pm
Might check the permissions and such in your security settings to see if by some odd chance that the hosting source site of his photos got set to be blocked in your browser.
I've had that happen for no explicable reason.
Alcohol does not solve any problem, but then neither does milk.
PRRK4s
Re: PRR Locomotives
Postby PRRK4s » Mon Oct 26, 2020 8:14 am
Image A rarely seen "Foamite" car for fire fighting. While the tender tank held the water, the shed housed the pumps, reels of hoses, canisters of chemicals and other tools that put the car into service. There was a small fleet of these spread across the entire system.
Re: PRR Locomotives
Postby Chris Webster » Mon Oct 26, 2020 10:02 am
big bad jim wrote:Still no luck on my end. I also can think of nothing that has changed that would cause the issue. My hope is that if something randomly changed that caused the problem, then some other random event may change it back eventually.
My guess is that something you're running is set to block images from a third party domain -- the trick is to figure what is doing that. It might be your browser, it might be your proxy server, it might be your firewall, etc.
Re: PRR Locomotives
Postby Rufus T. Firefly » Mon Oct 26, 2020 11:03 am
PRRK4s wrote:A rarely seen "Foamite" car for fire fighting. While the tender tank held the water, the shed housed the pumps, reels of hoses, canisters of chemicals and other tools that put the car into service. There was a small fleet of these spread across the entire system.
Now I know what to do next time I have an orphan tender in my shop! :wink: :wink:
PRRK4s
Re: PRR Locomotives
Postby PRRK4s » Mon Oct 26, 2020 12:07 pm
Rufus, my problem was I didn't have an orphaned tender for this project. So I had scratch build the 70f70 (of some subclass) tender. I didn't have the correct f31a flat car either so I started looking for it once the tender was underway. Found one and then started the shed build. On this particular model, the tender and shed, are anchored with magnets so if I ever need the f31a for its real purpose of container car it would be easy to repurpose. I think I built this in 2008/2009.
Re: PRR Locomotives
Postby Rufus T. Firefly » Mon Oct 26, 2020 1:25 pm
PRRK4s wrote:Rufus, my problem was I didn't have an orphaned tender for this project. So I had scratch build the 70f70 (of some subclass) tender. I didn't have the correct f31a flat car either so I started looking for it once the tender was underway. Found one and then started the shed build. On this particular model, the tender and shed, are anchored with magnets so if I ever need the f31a for its real purpose of container car it would be easy to repurpose. I think I built this in 2008/2009.
You have good fun!
Clever on the magnet trick - like that and will have to remember it :!:
PRRK4s
Re: PRR Locomotives
Postby PRRK4s » Mon Oct 26, 2020 3:09 pm
Image A photo showing the hidden magnet application. Double taped to the surfaces.
Re: PRR Locomotives
Postby rogruth » Mon Oct 26, 2020 3:51 pm
Good idea.
PRRK4s
Re: PRR Locomotives
Postby PRRK4s » Tue Oct 27, 2020 7:33 am
Image Another of my scratch builds. And the page that shows from beginning to completion. http://www.angelfire.com/film/prrpics/NX23index.html
Re: PRR Locomotives
Postby Rufus T. Firefly » Tue Oct 27, 2020 11:15 am
Neatly done!
